I Was wondering if i change out my stock rockers on my factory heads to Crane Cams roller rockers do i have to put studs in the heads for the rockers or can i just use my factory bolts?
As long as you get Crane PEDESTAL MOUNT rockers they will bolt right up on your car with the stock hardware, you will have to check them as some may need to shims under them.
I don't believe you can reuse the bolts on the stock rocker arms, because I think the crane rockers have a different head to it. I don't know whether the hex head of the stock bolts fits with the crane rockers. If I remember correctly, the pedestal mount crane rockers come with an allen key bolt.
