Rocker Arm Stud Conversion?
  • Thread starter Thread starter FeTTstang
  • Start date Start date Jan 17, 2007
F
FeTTstang
61
  • Jan 17, 2007
What is involved in converting my GT40P heads from pedistal mount to stud mount rocker arms??? Is all that is needed is studs and the stud type rocker arms? Or do you need some conversion kit?
89streetbeast
365
horton,ks
Jan 17, 2007
  • Jan 17, 2007
this is probly what your looking fer http://store.summitracing.com/partd...908331+4294840126+4294851051+115&autoview=sku
only thing you would need is 3/8's stud rockers. your choice of 1.6 or 1.7 ratio and different pushrods
TheBocSez
652
Converse, TX
Jan 18, 2007
  • Jan 18, 2007
I am running that kit on my Powerheads. It works great. Not recommended for insane spring presures as you are still only running a 5/16 stud into the actual head itself. Easy install and Crane makes a pushrod that is .117 longer just for that conversion with thier 1.6 energizer RR.
smr
167
Nor*Cal (Vacaville)
Jan 18, 2007
  • Jan 18, 2007
if youar egonna run a high spring pressure like switch from hydr to solid roller or something similar you could ge the head machined down for studs. I had to do it on my cleveland heads. its nto real expensive and doesnt take much....
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Engine Roller Rocker Stud Size, GT40P heads
  • foxbodyclark
  • Jan 25, 2025
2K
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
