Rusty67 20+ Year Stangneter Dec 3, 2002 3,749 37 109 LA, CA May 26, 2007 #1 May 26, 2007 #1 How much power do you need to be making before these do anything ? Is it more related to the HP/Tourque of the motor or the RPMs you are turning ? Basically, would I need to use a rocker arm stud girdle ?
brianj5600 Active Member Sep 19, 2003 1,964 2 39 Middle TN May 26, 2007 #2 May 26, 2007 #2 High spring pressure is when you need one. If you have a hydraulic cam you don't need one. A big solid roller or big mechanical cam, you need one.
Rusty67 20+ Year Stangneter Dec 3, 2002 3,749 37 109 LA, CA May 26, 2007 #3 May 26, 2007 #3 So how high is high spring pressure ? And I guess since Ford Motorsport cams are hydrolic I wont be needing them anyways ?
