Today, after driving home to school today, I stopped at the gas station to get me a coke, I start it up and make my departure home and the sucker makes this crazy sound, like the all the rockers are loose. So I find an open road and open her up and then listen for it, nothing. So im like yeah it fixed itsself, then the thing starts smoking out of one pipe, abunch of white stuff and a little blue, so I pull in my garage and let it idle, no rattling, smoked alot of white, it was gas cuz I smelled it. Then I let her cool down and took the valve cover off, checked all the rockers and get the last one on the pass. side and it felt really loose, so I took it off, sprayed the bearings with throttle body cleaner, and turn the bearings, one side of the rocker, the bearing falls apart and all the pins fall out, so now im stuck with a crappy rocker, I guess my question is: Would this be under warranty from ford racing? They are about 1-2 years old and look pretty new. The rocker is a 1.72 and they ride on fords shaft mount system that you can buy from ford racing, you dont have to have guideplates to run these either, kind of weird.
Thanks josh
Thanks josh
