Rocker ratio
loco556
18
Hopefully this is not too stupid a question, but what is the ratio on a stock 1986 5.0L? Secondly,I know they have roller tappets but what I am trying to sort out is if there is any advantages to installing roller rockers with the associated added cost? Lastly, are the mounting studs pressed in?:shrug:
Stock roocker arms are 1.6 ratio. Switching to roller rockers may have some added benefit but will not really be seen until more upgrades are done. I would wait to upgrade rocker arms until you decide to swap the heads. Also, stock rocker arms are considered pedestal mount, that is they are bolted down to a pedestal on the heads. Stud mount rockers require machining of the heads or heads designed for stud mounted.
Yeah get the right kind of rockers... ALso note that the factory stamped rockers are produced with very relaxed tolerences so you may see a few 1.55, 1.65 and so forth... Not the best thing for performance, a set of lightweight rockers will help the seat-o-pants meter.
If you plan on keeping the stock heads, get the rockers now. If you plan to upgrade heads later on wait.
Heads chosen
After contacting the techs at trick flow they responded by stating that gross cam lift determines everything.Normally with an undecked block and heads a cam lift of .500 or less will have no interferance. Yee haa
