  • 1994 - 1995 Specific Tech
rocky motor?
  • Thread starter Thread starter xYoung347x
  • Start date Start date Jul 17, 2004
xYoung347x
382
  • Jul 17, 2004
Is it okay to have a little to a medium shake to your engine? My engine kinda shake a little but then a little more. I know I can't expect it to be like a stock engine where its completly still, or can I? I have a 347 Stroker motor, AFR 185 Heads, Compcam XE274HR .565 lift .112 lope, ported RPM intake, and some long tube headers.
AznStanger3v
2,026
Northern VA
Jul 17, 2004
  • Jul 17, 2004
its called torque...learn to love it
HISSIN50
34
129
Jul 17, 2004
  • Jul 17, 2004
if you have doubts, check your motor mounts.
xYoung347x
382
  • Jul 17, 2004
I change them not too long ago but I'll check again. TTT
HISSIN50
34
129
Jul 17, 2004
  • Jul 17, 2004
are you talkin about shake when the motor is idling? with a built up motor (read cam) some shake is normal.
when you rev it, if the motor is moving a lot, i would address mounts, even if your 'look' alright. also, some run a strap on the side of the motor to limit the amount it can rock.
good luck.
mstangfrk95GTS!
203
  • Jul 17, 2004
hey this is a bit off topic but what are the manners like with that cam??
any drivability issues?
hows it on tha street?
a little shake with a lumpy cam is normal, is your balancer good/new?
xYoung347x
382
  • Jul 17, 2004
hissin it shakes when its idling but it smooth out when you rev it, so its okay?
HISSIN50
34
129
Jul 17, 2004
  • Jul 17, 2004
i dont want to speak out of school, since you guys run different puter and some other things that probably improve drivability (i have a fox). in my experience, most all 5.0's, even bone stock, have a little shake to them. the motor mounts have some room for movement (or else they would be like brutal solid mounts). so at idle, the motor oscillates a little. when you rev it, the torque loads the mounts and it stops shaking.
as long as you are sure your balancer is not outta whack, you should be fine, based on what you have said in this thread. always a good idea to keep an eye on them.
my two cents worth. good luck.
xYoung347x
382
  • Jul 17, 2004
The manners on this cam is pretty good for street. I don't have much of a drivability problem except for my overheating which I think its my bad stock gauge is the problem so its pretty good of a cam for street in my opinion.
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
1973 Headers
  • Stang_1973
  • Mar 11, 2025
1965 - 1973 Classic Mustangs -General/Talk- Apr 1, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
