Rod ends, how do they survive without lube?
R.O.B.
60
Just courious, but all of the suspension upgrades I look at seem to use rod ends. I never seem to notice a grease fitting anyware. Won't these wear out with out grease? Or is there something I don't get here?:shrug:
I decided not to take any chances, I used rod ends for my throttle linkage, I have a bumpsteer kit that uses them and I'm getting ready to install CalTracs. Summit has these and I've used them and will put them on the CalTracs just to be sure.
Here is a link to the part, Seal it
it depends on what type of rod end you use. if the old style two piece ends, then you replace them on a regular basis. the three piece ends have a teflon liner built in and last much longer. there are also ends that are lubeable and have seals you install to prevent dirt from getting in.
