77CobraII
Why is it that you have to run 50oz balance in the roller blocks? You are probably right, but I thought that you could use 50oz, 28oz, or even a 0oz balance in any of the blocks just as long as the spinning internals were matched. I looked into upgrading my non-roller block to be drilled and tapped to accept the spyder and planned to run a small solid roller (588 lift which is small in terms of solid roller). None of the places I checked told me I could not use this conversion with my non-roller block. I ended up finding a good deal on a set of used solid rollers with the crossbars, but never got to implement due to lack of budget. Not trying to argue, just trying to learn so next time I open my trap I can be more accurate and understand why. Thanks!
