Hi Guys
I was wondering what type of roller rockers would fit the SVO GT-40 Y303 aluminum heads, Pedastool or Stud Mount roller rockers? The rockers my engine bulider recomended where the 1.6:1 ratio. The cam im going to be running in the engine is the Comp Cams MAgnum with .533 Lift and 215 Deg Duration on the intake side, and .544 Lift and 220 Deg Duration on the exhuast side.
Also,
The complete engine is going to be running with 9.8-10.1 Compression 306 C.I. block with flat top pistons, GT40 Y303 Heads ported, Cobra Intake, Stock bottom end with factory rods but it's all going to be cryogenically treated for increased strength, 1 5/8" shorty headers, .533 lift Int. .544 lift exh. Cam, Jacobs 5.0 Ignition system, 3.55 rear gears, 73MM C&L MAF, 24lb/hr injectors, MAC CAI, 65MM throttle body. Any estimates on what the HP and Torque will be at the rear wheels with this set up
Also,
