Roller Rocker question
  • Thread starter Thread starter 88GTCobra
  • Start date Start date Jun 20, 2005
88GTCobra
33
  • Jun 20, 2005
Will installing 1.6 or 1.7 roller rockers on a completely stock engine make any performance improvements ??
Thanks in advance.
ram360
2,162
Pennsylvania
Jun 20, 2005
  • Jun 20, 2005
I read it in a 5.0 M&SF awhile back they dyno tested mods individually (can't remember what issue it was on) but I'm almost positive they lost 1 or 2 hp. It's basically a mod that helps you out when you have other supporting parts in place already.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jun 20, 2005
  • Jun 20, 2005
Lots of work for very little gain...like putting a cam in a stock headed car...just not the right order to work in.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 20, 2005
  • Jun 20, 2005
You can see a gain from 1.7RR's if your valve springs are in good working order. Reduced friction and a bit of increased lift. I was happy with mine. Don't expect nothing spectacular but you might feel the gain and you might not. Expect 5-8rwhp if the springs are up to par.
ramjetlx
212
Honolulu, Hawaii
Jun 20, 2005
  • Jun 20, 2005
Its much easier to install rockers then a cam. Theyre actually simple bolt ons, the adjustments are the most difficult part. Upgrade the springs and you will feel a difference throughout the powerband. I did get valve float with the stock springs over 5000 rpms, so its a good idea to change them.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Roller Rocker Stud Size, GT40P heads
  • foxbodyclark
  • Jan 25, 2025
2K
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
