I'm finishing up a rebuild on a 66 289 and wanted to install some roller Rockers, but there seems to be some problem installing them on these heads without doing some machining work or a push rod guide kit. Does anyone make a set that I can just install without modifying the heads? These heads are clearly marked 66 and have pressed in stids, but the book I have (motors Manual) said they should be screw in studs? also what is a rail type rocker arm Ive seen them on a 6cyl but not on a V-8 and all the catalogs call for both? Confused !!!
