roller rockers qustions
  • Thread starter Thread starter blk92
  • Start date Start date Dec 5, 2004
blk92
55
  • Dec 5, 2004
I have the pedestal mount fms roller rockers and i am bolting them to a gt 40 head that has been milled but only one will not get tight the pushrod is a little loose. Do i need shims for all of them or just that one and what is the part #. Thanks
P
ponyboy302
51
  • Dec 6, 2004
How loose is loose. Can you turn it very freely or is it just a little free? I know that when my friend and i adjusted the roller rockers some of the rods were a easly to turn.
shttygtstang
978
  • Dec 6, 2004
some need shims some dont you have to decide im shure some one will come along and tell you some pns but you might need to shim 3 and none of the others and then again none might have t be
281pony
2,681
Oly, WA
Dec 6, 2004
  • Dec 6, 2004
how much were the heads milled? can you tighten it anymore?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 6, 2004
  • Dec 6, 2004
Think about what you're saying - shimming it raises the rocker - that will make the gap between pushrod and rocker even greater! You don't need to shim it if the pushrod is already too short to close the gap. You need to LOWER the rocker down onto the pushrod or get a longer pushrod. You might try removing material from the bottom of the pushrod fulcrum until you get the rocker low enough to close the gap AND preload the lifter. Be careful....
Soupy
76
Rhode Island
Dec 6, 2004
  • Dec 6, 2004
Is that one lifter collapsed?
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Roller Rocker Stud Size, GT40P heads
  • foxbodyclark
  • Jan 25, 2025
2K
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
