roller rockers
  • Thread starter Thread starter 1991vert
  • Start date Start date Mar 24, 2004
1991vert
1,103
Ludlow, MA
Mar 24, 2004
  • Mar 24, 2004
i want to get a set of 1.7rr's for my new cobra intake and i dont know which ones to get. i have stock heads and cam and i just dont want to end up buying the wrong ones. can someone gimme a site on where to get them and the extact part#? on summit i found CRN-44746-16 but dont know if i fall under that one. ANY help would be appreciated.
thx
G
goldbomb79
374
Indiana
Mar 24, 2004
  • Mar 24, 2004
are you wanting to get pedestal mount rockers, or are you wanting stud mount? when you say you don't want to get the wrong ones, exactly what do you mean? j/w
1991vert
1,103
Ludlow, MA
Mar 25, 2004
  • Mar 25, 2004
i want to get stud mounted ones and what i mean by getting the wrong ones is that i dont want to end up buying something that wont fit my car. i decided to come here and ask before i made the mistake of getting the wrong ones. i heard that most of the rr's wont clear the stock valve covers. if i get taller ones will they interfere with the cobra intake im getting? j/w
thx
R
redterror302
895
Mertztown, PA or State College, PA
Mar 25, 2004
  • Mar 25, 2004
Just to let you know, the roller rockers have nothing to do with your cobra intake at all. I am not sure what you mean by, "i want to get a set of 1.7rr's for my new cobra intake." The stock valve covers will work, all you might have to do is remove the oil baffle on the passenger side. My friend ground down the metal inside to ensure no problems. As for the stock heads, they are pedestal mount, so I would stick with that. The part number you gave are the ones you want to get. They are not stud mounted, it says in the description that they are pedestal mount, only it lists the diameter of the "stud" or bolt it has. Those are the ones you want for your stock heads.
1991vert
1,103
Ludlow, MA
Mar 25, 2004
  • Mar 25, 2004
what i meant by 1.7's for my cobra intake was that i might as well switch them while im switching the intakes. so that part # on summit are the ones i want? i thought if i removed the baffles you can get oil in your intake through the breather hose?
R
redterror302
895
Mar 25, 2004
  • Mar 25, 2004
I have heard people question that, but have never seen that happen before. I helped my friend install them on his car, and when you would open up the oil fill cap, you could see the rockers moving, but no oil was spraying up into the tube. I am not sure how much more oil pressure there is in the valve covers at higher rpm, but I doubt you will have a problem.
Yes that part number is correct for your application.
1991vert
1,103
Ludlow, MA
Mar 25, 2004
  • Mar 25, 2004
should i just get like taller valve covers?
R
redterror302
895
Mar 25, 2004
  • Mar 25, 2004
No, the rockers get covered with oil anyway. They need to be lubricated because they are moving while the engine is running. The baffle is just there to prevent a possible occurance of oil going up the oil fill tube.
edit: If you want to get taller valve covers you can, but there is no need for it with the stock valve covers.
1991vert
1,103
Ludlow, MA
Mar 25, 2004
  • Mar 25, 2004
how hard is the baffle to get out? is it just a few bolts or is the sucker welded in there?
J
johnnyf
100
bayshore ny
Mar 25, 2004
#10
  • Mar 25, 2004
  • #10
i belive its 2 screws...
M
matm347
2,056
#11
  • Mar 25, 2004
  • #11
Mine had rivets that I just ground out...no biggie.
Crane made the 1.7 rockers that Ford put in the 93 Cobra, they are nice, so are SVO 1.72s(to get a bit more lift). You will probably want to go ahead and get a shim kit in order to adjust them once you get them on.
1991vert
1,103
Ludlow, MA
Mar 25, 2004
#12
  • Mar 25, 2004
  • #12
i need to get a shim kit? how hard is it to install roller rockers? thought it was basically a direct swap?
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
