Rolling fenders question.
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date Apr 27, 2009
65fastbackresto
1,229
AR
Apr 27, 2009
  • Apr 27, 2009
Thinking of cutting relief cuts about every inch or so and using hammer and dolley to "round" it upward. Anyone know of pros and cons to such a simple plan?
I just need a little bit of tire clearance on the front fenders.
hivewax
233
Miami, FL
Apr 27, 2009
  • Apr 27, 2009
paint will crack when old. heat gun won't help. i missed the lip a couple of times and made a few dings as well. i used black silicon sealer to keep moisture out. oh, i made no relief cuts.
65fastbackresto
1,229
AR
Apr 27, 2009
  • Apr 27, 2009
My car has the chrome inserts
On the fender well lip, I figured by relief cutting maybe 3/8 of an inch or so I could keep them and maybe you wouldn`t notice unless you were actually in the fenderwell with it. Don`t you just have to do the top of the fenderwell, like maybe 8 inches worth or so?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Apr 27, 2009
  • Apr 27, 2009
Unless you are a DaVinci with hammer and dolly, it will look like somebody whacked it with a hammer. You need to borrow, rent, or pay someone who has one of these:
65fastbackresto
1,229
AR
Apr 27, 2009
  • Apr 27, 2009
I`m not doing it.
My buddy has been a body man for 30 years, he is gonna do it, my fenders are crap anyway, I just want to be able to drive it without ruining my tires.
10secgoal
2,801
San Diego
Apr 27, 2009
  • Apr 27, 2009
Don't cut it. If you do you will have a crease at every cut. Looks horrible.
Tony R
102
Vancouver Wa
Apr 27, 2009
  • Apr 27, 2009
I did mine with out cutting. Mine is in the primer stage though.
65fastbackresto
1,229
AR
Apr 27, 2009
  • Apr 27, 2009
I`m glad I posted this.
I would have wrecked it for sure. Thanks alot guys.
Oh, and glad to be back, I haven`t been around since last fall, car was hibernating for the winter.
coolblue65
1,224
Algonquin, IL
Apr 27, 2009
  • Apr 27, 2009
not saying its the best way, but the previous owner of my car put a cuts in before rolling the fenders, visually I see no ill effects from it.
mtaqua
345
#10
  • Apr 27, 2009
  • #10
I used a hammer, can't tell from looking at it. I didn't make cuts.
bnickel
5,640
lubbock, texas
Apr 28, 2009
#11
  • Apr 28, 2009
  • #11
did my car with a hammer and dolly before it was painted and you do only have to roll the tops in most cases however to be on the safe side i like to go about half way around the wheel well. if you are working on a painted fender you can also use a rubber mallet and a block of wood instead of the dolly, you'll probably still get some paint cracking but not as much with the rubber mallet and the wood will keep you from chipping the paint like a dolly would on the outside of the fender
chris66dad
167
Benicia California
Apr 28, 2009
#12
  • Apr 28, 2009
  • #12
I used the Harbor Frieght fender roller. Pretty much the same as the Eastwood unit but was only 80 dollars. Be sure to use a heat gun to soften the paint on the lip before you start. Trick is to go slow and not to roll too much at one time.
here is the link:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
65fastbackresto
1,229
AR
May 1, 2009
#13
  • May 1, 2009
  • #13
He used hammer and dolly
Took him about 20 minutes total to finish and we didn`t even have to remove the chrome inserts in the fenderwells, they just bent around too. He sure made it look easy guys, I wouldn`t be afraid to try that myself and I`ve never touched a body hammer or dolly before.
He wouldn`t even let me pay him to do it, said it didnt take long enough.
iskwezm
4,159
20
79
Rowland Heights,California
May 2, 2009
#14
  • May 2, 2009
  • #14
if anybody is worried about cracking the paint, take a razor and cut a line in the paint and it will only chipt to that line
suki243
662
Southern California
May 2, 2009
#15
  • May 2, 2009
  • #15
Wow, you're lucky i think i was getting quoted at 200$ a fender to get my lips rolled...
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Progress Thread Roll cage and LS swap?????
  • 78mIIman
  • Dec 30, 2024
1974 - 1978 Mustang II Talk & Tech Mar 30, 2025
greenflash79
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
