  • SN95 4.6L Mustang Tech
Romeo....Windsor...Differences????
  • Thread starter Thread starter 96 GT JOE
  • Start date Start date Apr 24, 2006
9
96 GT JOE
56
  • Apr 24, 2006
Hey guys I have a 96 GT 5 spd and i am planning to do a p.i. headswap, LT header, and dyno tune. I need to know what the differences are between romeo and windsor. I know the valve covers are different so i want to make sure that i have all the right stuff, or if i would be better going with parkway performance complete kit. thanks.
BLKsteeda
236
Anywhere
Apr 24, 2006
  • Apr 24, 2006
you can count the bolts on your valve covers...11 bolts = Romeo, 13 bolts = windsor.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 24, 2006
  • Apr 24, 2006
I think there is also a slight compression difference in the 2 motors
BTW, Windors are better
T
TGJ
1,049
  • Apr 24, 2006
For your PI swap, you want 01+ parts. Those are Romeos, which is what your current motor is. You will need less parts going this route.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 24, 2006
  • Apr 24, 2006
So the 96-98 4.6's are Romeos as well? Didn't something happen in 99-00 that forced the Ford to use the Windsor blocks?
dollarbill
140
Decatur, IL
Apr 24, 2006
  • Apr 24, 2006
To make Windsor heads work on a Romeo, you need different front cover bolts/studs and you need the Windsor cam covers. I recently researched this because I had a set of Windsor heads I was gonna use. Read this: http://forums.stangnet.com/showthread.php?t=570515&highlight=prepared+headswap
jasonh_86
I
May 20, 2005
1,156
Arkansas
Apr 24, 2006
  • Apr 24, 2006
The Romeo block was from mid '01-'04.. They came with bolt-on cam gears, instead of the press-on used by the windsor block.
You want to go with Romeo heads/cams, that way you won't have to buy new cam gears and crap later on down the line. Romeo also has higher compression and 11 bolts on the valve covers.
bluestreak_96gt
51
Jacksonville, Florida
Apr 26, 2006
  • Apr 26, 2006
I did the head swap with 01' heads. I just used the original valve covers that were on my non pi heads. Becuase I intinally bought the windsor covers and they were 13 bolt which didn't fit, but luckily my non pi cover fit perfectly with the 11-bolts. So I junked the windsor covers instead. So check your covers out, before shelling out more cash. just a tip.....
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Any 1 find any decent blackfriday sales for Foxbody or car stuff?
  • rednotch
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 19, 2025
rednotch
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
