I have a 69 302 and I just finished a C4 to a TKO swap.
I Installed the stock height ron morris mounts. The problem I am having is that the engine is rolled right. This is creating an angle and a gap at the transmission mount. (See attatched Picture)
--- I did not have this problem with the original factory mounts that I had.
--- Im not ruling out my cars frame, but its frame is pretty damn straight. I dont have problems with alignment and I dont feel any kind of flexing while driving.
I did manage to get the transmission mount seated even with the angle. I have already driven about 300 miles and I do not have any vibrations.
Since I dont have any vibrations, would it would be ok to just leave it as is? If not, how would you guys recommend fixing it?
This is the moderndriveline crossmember and it drops the trans down quite a bit. I have PLENTY of room ro raise the trans from half inch to maybe even a whole inch.
I think the easiest thing to do would be to put a jack under the transmission, loosen the trans cross member to frame bolts, get it nice and seated on the rubber mount, then jack up the trans to the desired height and redrill holes for the cross member.
