Rotor/Bearing question...
  • Thread starter Thread starter Mavrick
  • Start date Start date Sep 14, 2004
Mavrick
2,264
Collingwood, ON
Sep 14, 2004
  • Sep 14, 2004
I did the brakes last fall, and the car hasn't been driven since.. has just sit on jack stands. I had to remove the rotor today while trying to do my balljoints, and when i took the rotor off, the outter bearing just fell right out, and the inner bearing along with the rubber seal stayed on the spindle.
Is this normal or are they supposed to be pressed good into the rotor?? Everything was heavily greased ofcourse.
axeman
1,348
Elizabethtown, PA
Sep 14, 2004
  • Sep 14, 2004
the bearings should come off easily. they will fall out. the races are pressed into the rotors and should not come out too easy.
Mavrick
2,264
Collingwood, ON
Sep 14, 2004
  • Sep 14, 2004
OK thanks, the races are still in there.
I'm buying new rotors and bearings, i take it the races comes with new rotors eh?
axeman
1,348
Elizabethtown, PA
Sep 14, 2004
  • Sep 14, 2004
the races will come with the new bearings. just pound them in with a punch or something. just don't mar the part where the bearings will ride on.
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Sep 14, 2004
  • Sep 14, 2004
Kinda scary how the front rotors bolt up.
Everything is a loose compression fit. The only thing keeping your wheel from falling off is a small nut torque down in INCH-pounds.
battyice
153
West Chazy, NY
Sep 14, 2004
  • Sep 14, 2004
Most new rotors for your car will come with races and wheel studs already pressed in.
axeman
1,348
Elizabethtown, PA
Sep 14, 2004
  • Sep 14, 2004
learn something new everyday. i never bought new rotors. come to think of it, the races might not come with the bearings, they might be seperate.
Mavrick
2,264
Collingwood, ON
Sep 14, 2004
  • Sep 14, 2004
Exactly what i was thinking!
Thanks for the info guys, i'll be ordering some new rotors next payweek. I'm going with the 73mm calipers as well.
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Sep 15, 2004
  • Sep 15, 2004
The rotors are an integrated rotor and hub with the races as part of the assembly. It's all 1 peice.
All you need is the rear grease seak, inner and outer bearings and a cotter pin and that's you basic front brake rotor swap.
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
  • JRC99
  • Apr 19, 2025
JRC99
J
@#$%!! Should be simple! Raybestos 6984R Rotors, hit dust shields! DANGIT!
  • JasonRP
  • Sep 9, 2021
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2021
7991LXnSHO
D
1994 GT issues
  • DLB1985
  • Jul 2, 2022
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 2, 2022
General karthief
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
