Well I put my car back together today and it's running very very bad.
When I start the car it has a very tough time Idling right, at first it's low then it will "rev" up on it's own and stay at a higher idle (around 2-3K) Then drop down again, it is very irritating.
I have the following mods done to it right now.
Mac LT's
Mac O/R H Pipe
Granatelli Big M 90 MAF
70mm TB
C&L Intake plenum
SCT Xcalibrator2 which is tuned for all those mods.
If I Tune it to stock it has 11 Engine codes.
I really don't know where to start, I know it has to be something with the O2 sensors, but what could it be.....could it be a vacum leak???
If someone could please help I'd appreciate it.
I have listed the engine code below.
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1
P0155 Upstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0443 EVAP Canister Purge Control Solenoid or Valve Faulty
P1000 OBD-II Monitor Testing Incomplete.
P1409 EGR Vacuum Regulator circuit malfunction
P1451 Lack of Response From Passive Anti-Theft System Module - Engine Disabled
Thanks
JT
Mac LT's
Mac O/R H Pipe
70mm TB
C&L Intake plenum
Thanks
JT
