Howdy....again,
Well, it seems that I am on here over and over again for one problem after another. This time its a rough idle. As I stated before the idle on my car is rough, shaking and lurching at a stop and making pulsing noises, at about 600 rpm. I was running through the four steps listed in other posts, I cleaned the IAC, cleaned the throttle body, and went to change the base idle. The article says to disconnect the batter, disconnect the IAC plug, reconnect the battery, start the car and then reset the idle with the idle screw. The problem is the car WILL NOT start without the IAC plug, plugged in. If I unplug it it will stall the engine EVERY TIME. I changed the cap and rotor, and checked the plugs it all looks good (although a wire and plug swap are within a few days).
I tried to simply twist the screw but the idle DOESN'T change at all, so is there another way to adjust the idle? The plug I was unplugging the one that goes into the top of the IAC, is this the correct one? Once the car is moving she runs very well no missing or even a hiccup just the extremely rough idle.
One more time my stangnet brothers (and sisters?) my car needs you!
Thanks a lot!
Thanks a lot!
