BigRed95 said:
I pulled the same 511 code about the Pcm rom failure. I didnt recieve this until after doin a h/c/i swap and a new chip. If anyone knows that this menas and how to fix it, i tihnk it would help me and some others. Thanks!
Very very good chance it's the chip. No bigs.
Mike, I couldnt think of other things to contribute (hence my not posting further info). I just re-read it and am still not coming up with things. One main reason I decided to fix my media player was to hear/see your clip.
You would need ample grounding from the engine to chassis (the chassis is what completes the ground pathway).
If it feels like someone actually turned the car off for a split second, I'd double check the primary power connections (battery, power distribution block, etc). Been there and done that on a rear battery car (the run of cables seemed to exacerbate an issue I had).
For your miss (if not related to above), have you taken a peek at the PIP? I check real quick for slop in the components (mainly dizzy shaft run-out and build up of chit on the shudder). I spray the sensor down with contact cleaner occasionally because I get a ton of dust under my cap.
I like doing the plug-wire light-show test idea too.
I'm just tryin to think of quick little things that could be it, or that can be checked off the list. You have modded and deleted enough stuff otherwise that I'm not sure how it would react or what symptoms might pop up.
Good luck brah!
