rough idle, popping sound
i know i have asked this question on here, but before i decide to purchase parts i was going to make sure and see one last time if anyone has any ideas. I have what my mechanic considers a ROUGH IDLE (it was bad enough he commented on it), (he has a supercharged 5.0 and 2004 mystichrome cobra), Anyways it also makes a popping sound which my mechanic says is a LEAN MISFIRE, so i got some suggestions here and the main consensus was too replace the EGR and the TPS sensor, anyone else have any suggestions to what this might be? THANKS FOR YOUR TIME!
Mine acted the same way. It turned out that I had a crumbling, leaky vacuum hose under the upper intake. Pull your upper intake off and check all the hoses and connections before you go buy any parts. I bet this is your problem.
Where is the popping sound comming from? If its through the intake its lean most likely due to a bad vacuum leak. Do a code test before pissing away money on parts that won't help the issue at hand.
