Rough Idle
  • Thread starter Thread starter txplayboy001
  • Start date Start date Nov 30, 2004
T
txplayboy001
47
  • Nov 30, 2004
Just bought this one last week, working through the bugs and nic nacs.
1992 5.0 LX
Just did a COMPLETE tune up. Put a new MSD coil in. Had the fuel system cleaned. Throttle body and intake has been cleaned. No codes. Runs great during acceleration and crusing. Completely stock motor. Has K&N, dumped flows.
I am having a problem at idle. Very rough idle. Any ideas?
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 30, 2004
  • Nov 30, 2004
Vac leak
87'GTstang
1,025
  • Nov 30, 2004
Run a vacuum test to see if you are pulling the industry standard of around 15"-22" hg first. What rpm does the engine idle at? Lastly, is it a stock cam or heads ect. - basically are all the major induction/power components stock?
T
txplayboy001
47
  • Nov 30, 2004
Motor is completely stock. I did fix two vaccum leaks. (those damn flimsy plastic vaccum lines) I could not find any more leaks. I will put a gauge on it to be sure.
T
txplayboy001
47
  • Dec 1, 2004
I have 19 hg vaccum. I fugure thats good enough. Any more suggestions?
shttygtstang
978
  • Dec 1, 2004
clean your iac see what your tps voltage is does it have a cam ....spray carb cleaner around the intake see if the idle picks up if it does you have a leak
T
txplayboy001
47
  • Dec 1, 2004
No Leaky
No leaks anywhere. Sprayed all around the intake and all vaccum connections.
Also, cleaned iac, don't have a meter with me today for the tps.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • Gulftown980x
  • Jul 29, 2026
squeak93
