  • 1994 - 1995 Specific Tech
Rough Idle
  • Thread starter Thread starter fivemustangs
  • Start date Start date Aug 28, 2009
fivemustangs
222
Bar Harbor, Maine
Aug 28, 2009
  • Aug 28, 2009
I have recently had my car tuned with a mustang dyno, When I got the car back the HP was a lot lower then it was rated for as described in another thred I posted. But the problem I am facing now is when I start the car it reves up to about 2000rpm and takes about 10-15 seconds to get down to 900 were it idels at. Then when I am crusing down the road and I put the clutch in it does the same thing but takes only about 5-7 seconds to get back down to idel. But the most annoying thing is sometimes when I put the clutch in the cars rpms drop down to 0 and stalls out and I can understand why! its not all the time but often enough to be a pain in the ass! So if someone could please point me in the right direction that would be great!
Thanks
HISSIN50
34
129
Aug 28, 2009
  • Aug 28, 2009
Look for a vac leak.
Stanger007
2,015
Baton Rouge, LA
Aug 28, 2009
  • Aug 28, 2009
I would take it back if it has done that since the tune. The car should drive like stock or better after it is dynotuned!
Wes
fivemustangs
222
Bar Harbor, Maine
Sep 1, 2009
  • Sep 1, 2009
I thought maybe vac leak to but the idle gets back down to 900 were he set it, but its just a little slow. I should take it back and have him fix it, but I don't want him to mess anything else up, not sure if he really knew what he was doing. also still not sure about the stalling?
2Many
11
  • Sep 1, 2009
Check the IAC. I had weird issues with one, when let off it would stay high and slowly come down.
I was never able to get it to work right with the my PMS System.
Not sure if it was the tune or bad IAC, sticking.
It is unplugged now. With it unplugged it won't idle til warmed up a lil, but after that it idles fine and throttle revs up and down perfect.
I don't street drive this car anymore so I didn't care about cold start.
I would think you could warm up the car and then unplug the IAC and see if the hanging rpm problem goes away.
Just a suggestion.
Good Luck.
C
corey97svt
34
Knoxville, TN
Sep 7, 2009
  • Sep 7, 2009
On my 94 I had to unplug my iac completely and create a vac. leak to get my car to idle it had similar symptoms.
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Dipstick Issue?
  • Sonic
  • May 2, 2026
1994 - 1995 Specific Tech May 5, 2026
WhiteCobra95
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
