Roush 427R in a 68 Stang!!!
diverdaveman
45
I just ordered a Roush 427R which is a Dart 351W block. I’m unsure on which motor mounts to use. I know there are three components to the mounts: engine mounts, insulator, and shock tower mounts. There was no option in 68 for a 351 engine, so when I go to order my 3-component engine mounts, what do I get? Any ideas?
Thanks...
For an engine pumping out the sort of power that beast makes, I would suggest Total Control or Ron Morris engine mounts. Pricey, but factory mounts won't live long with that engine. Nice choice if you have the $$, which you obviously do since its ordered. Let us know your impressions after putting it through the paces.
Cobra5.0Jeep said:
LOL yeah i meant it as a slang word not meaning it would be a tight fit.
tight = cool.
I plan on dropping a real 428 bigblock in my 68.
So, tell us, (who are confused now), what engine in what car do you want mounts for ? 428 in a 68, 427 in a 68, or a 351W based stroker in a 68 ? :shrug: bnickel had it right for a 351W based stroker, you just need regular small block mounts. If your question was about an FE series 427-428, you need the block brackets, frame brackets and insulators.
I am going to put a MII suspension in and then i want to put a 428FE motor in. I don't know if it'll work with those three things. Theres no mounts that i can bolt onto the MII with will work with a 428?
if you have the skills to install a MII then you should have the mechanical inginuity (sp?) to fab up some simple motor mounts...
when putting in our 4.6 into a 66 with a MII we used the heidts motor mount kit (that bolts to the MII crossmember) then took a stock 4.6 mount, chipped out the rubber and bolted that metal piece to the bracket...
i was just hoping there was an easier way than making my own mounts.
