  • SN95 4.6L Mustang Tech
Roush suspension package
  • Thread starter Thread starter Black'03GT
  • Start date Start date Mar 18, 2004
Black'03GT
31
PA
Mar 18, 2004
  • Mar 18, 2004
Roush sells the stage III "V8" suspension package on their website. It includes front and rear springs, struts, shocks, rear lower control arms, frame connectors, sway bars, pinion snubber, offset rack bushings and hardware.
Anyone have this setup? Is it any good?
03SteedaGT
82
Knoxville, TN
Mar 18, 2004
  • Mar 18, 2004
What are they asking for that kit?
U
u_s_marine
91
  • Mar 18, 2004
Its a roush kit so $$$$$$
Firemanz
Only you can prevent Forest Fires!
4,105
San Antonio, TX
Mar 18, 2004
  • Mar 18, 2004
I have everything except the SFC's and it handles like it's on rails.....
BLKVERT
407
SATX
Mar 18, 2004
  • Mar 18, 2004
Why not create your own set-up, it will definalty be cheaper for you and you can hand pick what you want. That kit is probably mucho denero. IMHO, create your own set-up, and you might just end up saving yourself more mod money.
Black'03GT
31
PA
Mar 18, 2004
  • Mar 18, 2004
the kit is listed on roush's website for $1,923.13 though YearOne lists the same kit for $1649.00 This a good deal? It includes alot of upgrades.
H
Hoppy
329
L.A. CA
Mar 18, 2004
  • Mar 18, 2004
This is what $1,568.78 will buy at Maximum Motorsports
The Sport Box = includes the following parts:
MM Strut Tower Brace 4
MM 4-Point K-Member Brace
MM Standard Subrame Connectors, bare steel
MM Panhard Bar with Aluminum Rod
H&R Sport Springs
Tokico Premium Performance Front Struts
Tokico Premium Performance Rear Shocks
MM Caster/Camber Plates
MM Urethane Pinion Snubber
Front Spring Isolators
Rear Spring Isolators
Steering rack bushings, urethane
Front Swaybar bushings
Front Swaybar end link bushing kit
This is what $2,382.79 will buy at Maximum Motorsports
The Road & Track Box includes the following parts:
MM Full Length Subframe Connectors
MM Heavy-duty Rear Lower Control Arms
H&R Race Springs
Bilstein front struts
Bilstein rear shocks
Front spring isolators
Rear spring isolators
Solid Steering Shaft
MM Aluminum Rack Bushings, center drilled
Front control arm bushings, urethane
This is an easy choice to make, get some MM stuff on your car!!!
Hop
EDIT = Italics show the differing components
O
Back in a Fox
  • Osorio299
  • Jul 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 25, 2026
gkomo
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
