Ok im getting ready to mount a tach on the right side of the cluster but how can i route the wires? this is my first SN95 the fox was a bit easier when it came to this.
i popped the clock off the dash and put the wires thru there...then i made a little notch in the back of the clock so the clock sit flush flush on the dash...im not sure if this is wut you are askin or if your askin where all the wires go....i can tell u that too if u wanna know.....hope this helps
This may sound hard but is easy, I took my speedometer out so I could get my hands in to run the wires, my tach is sitting next to my clock it looks killer too! once i found where i wanted to bolt it down i drilled a small hole under the mount to put the wires thru with a clothes hanger, ran the wires along with the the existing wires from the spdo all the way down to the side kick
panel under the carpet and you will see where other wires are running out the
car thru the fire wall, also the fuse box in the car is where i ran the other wires with out people seeing them. a very clean look. there is one wire that is going out to hook to the coil, on the coil i want to say it will hook to the wht wire. I can go out and look at mine if you don't know but i'm pretty sure someone will correct me! Good Luck
