Whenever i start the car in the morning, the car idles fine around 1100rpm, then after it warms up, it drops down to 850rpm. but after its in the driving temp the RPM drops around 650-700RPM and i also notice the battery meter drops down to R on NORMAL, but when its started in the morning its on M. What do you all think is causing it? Is there a way to raise the RPM up on idle back to 850. What is the factory set at? The TPS sensor wire coating is peeling off, can that be the problem? I have cleaned the MAF and IAC and not much help. any suggestions??
