T-bird tach test
Ok, I am a Cougar/Thunderbird fan. I recently traded a 97 Cougar that I liked a lot (got a good deal). OK. the reference I have is for the 96 MY. There are differences but I hope they will not be too great.
OBTW, the tach signal comes from the PCM.
For what you are trying to do, you may need your own copy of the wiring diagrams. If trying to ohm out wiring harness, the connector diagrams are invaluable.
The hard copies or CD can be purchased from ebay.
>>>From 1996 Ford service CD Cougar/T-bird
PINPOINT TEST H: TACHOMETER NOT REFLECTING ENGINE SPEED
H1 CHECK SUPPLY CIRCUIT 640 (R/Y)TO GAUGE
l Turn ignition switch to OFF position. Partially remove instrument cluster as outlined, to gain access to the cluster connectors.
l Turn ignition switch to RUN position.
l Using a voltmeter, check B+ at Circuit 640 (R/Y) at Connector Pin C1-11.
l Is battery voltage present?
Yes
GO to «H2».
No
SERVICE Circuit 640 (R/Y) for open. RESTORE vehicle. RETEST system.
H2 CHECK GAUGE GROUND
l Using an ohmmeter connected to a known good ground, connect second lead to Circuit 651 (BK/Y) (875 (BK/LB) with 4.6L engine) at connector Pin C1.
l Measure resistance.
l Is resistance 5 ohms or less?
Yes
GO to «H3».
No
SERVICE Circuit 651 (BK/Y) or 875 (BK/LB) with 4.6L engine for open circuit. RESTORE vehicle. RETEST system.
H3 CHECK TACHOMETER INPUT CIRCUIT 648 (W/PK)
l Disconnect cluster connector C1.
l Disconnect ignition coil.
l Using an ohmmeter measure resistance of Circuit 648 (W/PK) from ignition coil connector, to instrument cluster connector Pin C1-18.
l Is resistance 1.8K ohms?
Yes
GO to «H4».
No
SERVICE Circuit 648 (W/PK) for open. RESTORE vehicle. RETEST system.
H4 CHECK TACHOMETER
l Reconnect cluster connector C1.
l Using an ohmmeter, check for continuity at all tachometer connector clips.
l Is there continuity?
Yes
GO to «H5».
No
REPLACE tachometer. RESTORE vehicle. RETEST system.
H5 CHECK INSTRUMENT CLUSTER PRINTED CIRCUIT
l Using ohmmeter check each circuit per chart for continuity from gauge connector clips to cluster connector C1.
C1 CONNECTOR
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Pin ³ Circuit ³ Function ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ 1 ³ 651 (BK/Y) ³ Ground ³
³ ³ 875 (BK/LB)(a) ³ ³
³ 11 ³ 640 (R/Y) ³ RUN/START Power ³
³ 18 ³ 648 (W/PK) ³ Tachometer Input ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
(a) - 4.6L engine only
l Is there continuity at all circuits?
Yes
No
REPLACE instrument cluster printed circuit. RESTORE vehicle. RETEST system.
