  • SN95 4.6L Mustang Tech
RPM Not Steady
  • Thread starter Thread starter DanmMh
  • Start date Start date Jul 20, 2011
D
DanmMh
  • Jul 20, 2011
HI, i just bought a 2000 mustang gt manual and i realized that when the car is on the RPM goes up or down, its not steady, and when im on a light and im just waiting for the light to change the RPM goes really down almost to shut down the car, Can somebody help me please ? i thought that with a Fuel injection cleaner was going to stop but it didn't stop.
Thanks for the Help !
D
Deleted member 38176
Jul 21, 2011
  • Jul 21, 2011
Try cleaning your IAC and MAF
D
DanmMh
  • Jul 21, 2011
If i Buy the JLT Performance Cold Air Intake (96-04 GT) do i still have to clean the AIC and MAF ? or that would eliminate that part ?
D
Jul 21, 2011
  • Jul 21, 2011
A CAI retains the MAF and IAC. They are essential to how your engine runs.
Your local auto parts store carries a simple MAF cleaner. Its just an aerosol solution that you spray your MAF sensor with.
As far as cleaning your IAC, this should help....
Ford Mustang IAC IAB - Solving your idle problems
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 21, 2011
  • Jul 21, 2011
grasshopper, to answer that question you need to tells us why the RPM's are bouncing.
If for example the root cause is a bad PCV valve, then installing a new TB will not fix the base problem.
If the problem is an upper intake vacuum leak or weak ignition, then a new TB will not fix the problem.
On the other hand, if the base problem is loose or worn throttle butterfly linkage, then a new TB would improve the reported symptom.
Are you just looking for justification to upgrade?
OBTW, +1 on clean the MAF.
check out:
http://www.allfordmustangs.com/forums/2260649-post.html
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
