  • Special Production
Roush RPM Spike
  • Thread starter Thread starter mkkrs1
  • Start date Start date Jun 27, 2005
mkkrs1
49
indian trail,nc
Jun 27, 2005
  • Jun 27, 2005
Have any of you Fox body owners encountered this problem. When I shift gears the rpm spikes up a sticks when driving normal. If I shift around 1800 the rpm will climb to 2200-2400. Need to get fixed before mustang week.
mike 89-718
SGOODRIC50
130
Maine
Jun 27, 2005
  • Jun 27, 2005
Yes, I have experienced that problem. It was something on the actual transmission that was causing it. I am not sure exactly what it's called, but if you go to your local autoparts store they can look up everything related to the tranny and find it very easily. Good luck
marcus95
2,133
California
Jun 28, 2005
  • Jun 28, 2005
mike 89-718
Sounds like your IAC ( idle air control ) to me. It's that small cylinder unit bolted to the front of your throttle body. Just a shot in the dark but wrap on that with the end of a screwdriver or something that wont damage the outside and see it that clears it up. How many miles? Occasionally, they need to be replaced. Hopefully Casey from Haney Motorsports will chime in and verify what the probelm is. Sounds like something in that area of idle control.
FASN8N
517
Atlanta, GA
Jun 28, 2005
  • Jun 28, 2005
Could also be a throttle position sensor out of range (TPS). You can check the voltage and it shoud be set as close to 1.0 volt w/o going over. .96, .97. 98 etc.....
H
HMSPORT
Banned
Mar 30, 2005
60
  • Jun 28, 2005
That is what I would say is the problem. Take the IAC valve off and try cleaning it out with some brake clean. They do get gummed up inside after awhile. It also can be a possible TPS voltage/thottle blade set idle adjustment. Sometimes when the TPS volts a low, the processor sees that and activates the IAC. Then you start having a hung up idle. Ford has an adaptor plate that goes between the t.b and the IAC. It has a couple of set screws that allow more or less
airflow (bypassing the IAC). This is a good idle tuning peice especially if you have a big duration cam. I think the p/n is
F2PZ-9F929-A
mkkrs1
49
indian trail,nc
Jun 28, 2005
  • Jun 28, 2005
I have cleaned the IAC but I have not checked the TPS voltage. This is a stock 89 saleen with 93k. Does any one know if you replace the TPS or IAC do they have to be calibrated or is it a remove and replace that simple.
FASN8N
517
Atlanta, GA
Jun 29, 2005
  • Jun 29, 2005
If you remove/replace the TPS it has to be calibrated.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sunday at 11:45 PM
Ryu
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
T
Buzzing Noise on auto 1990 GT gear change 1800 - 2200 RPM
  • Tom77
  • Apr 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2025
Tom77
T
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
