RPM Sticking...
97GTSTANG
852
Virginia
Just wanted to know if anyone has or have had this problem before. THe car drives fine but whenever i come to a stop the RPM stays at 1200 and then slowly drops back down to 850. It never used to do that before the PI headswap. I was wondering if its normal or something is goign on?
I checked all vacuum hoses and everything is fine, the car drives very well but its when i stop at a light it takes a few seconds for the idle to drop back down to 850rpm. How will i reset the computer?
To reset the computer disconnect the bat for 10 - 15 mins and reconnect.
Im a newbie, but is it possible you need to upgrade your computer to componsate for the new setup ?
Asking/Suggestion
I have disconnted my battery several times before for over 30min and it does the same thing. I am just going to clean the IAC and see if that helps. I think spraying it with Brake Cleaner will help. Yea i have a 5.4L swap
