  • 1994 - 1995 Specific Tech
rpms are acting weird
  • Thread starter Thread starter 94gt5.o
  • Start date Start date May 25, 2010
9
94gt5.o
177
ferndale WA
May 25, 2010
  • May 25, 2010
So when im driving or even at an idle I will rev up the car and the rmps drop super slow if im driving and push in the clutch the rpms will actually jump up then the will hang there for a couple seconds. I have no clue what it is please help, thanks guys
TrueBlue95GT
966
Connecticut
May 25, 2010
  • May 25, 2010
When did it start happening? It usually means you need to adjust your idle settings.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 25, 2010
  • May 25, 2010
Before you go playing with the idle screw, pull off your IAC and give it a good clean up. Visually inspect the rest of the throttle body for gunk and carbon deposits as well. Testing your TPS function wouldn't hurt either. In any case, the stock throttle bodies are factory set so you shouldn't have to touch the idle.
BlackVert
5,589
9
98
Bethesda, MD
May 25, 2010
  • May 25, 2010
sounds to me like the IAC is starting to stick a little. cleaning it might help for a while, but my understanding is that there is a coating that is supposed to help keep it from sticking. after it is cleaned, the coating does not work as well anymore, so it will start sticking again before long.
if you can verify that it is the IAC, then you should replace it.
9
94gt5.o
177
ferndale WA
May 25, 2010
  • May 25, 2010
Ok thanks guys ya ive never cleaned the IAC and i will get a price quote at the local parts store for the IAC and i will get back to you guys after i take a look at it.
9
94gt5.o
177
ferndale WA
Jun 8, 2010
  • Jun 8, 2010
ok so i bought a new IAC and tried setting my idle settings and now my car has lost some noticeable throttle response. I checked my TBS voltage reading of .95 is this good enough? oh also another problem i can not set my timing at 10 degrees timing other wise it makes a horrid noise when i get on it the noise starts around 3000 4000 RPMs i have to set my car at 7 or 8 degrees to get it to stop. any help would be great thanks guys.
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Jun 8, 2010
  • Jun 8, 2010
balancer may be spun, is it the original? tell tale sign (not so much of it being spun, but wore out) is rubber hanging out of it. may be time for a new one. in effect, you may try to set your timing at 12, but its actually 20 (random numbers) rubber wears out, outer ring spins away from inner ring, timing marks are off, it happens....
good luck
brightredvert
Georgia
Jun 15, 2010
  • Jun 15, 2010
It's kina off the wall but does your stang seem to be running richer and worse mpg???
I'd check the O2 sensors.
I'm having the same Idle and timing problem with my 94 GT I replaced a harmonic balancer about 8 months ago. When the balancer goes you will get a heavy and I mean heavy vibration from the engine.
You might want check your ignition system (distributor, Cap, rotor, SPOUT etc) if all other things listed above seem to be O.K.
Un plug the SPOUT and see if the problem is still there.
9
94gt5.o
177
ferndale WA
Jun 15, 2010
  • Jun 15, 2010
you know come to think about it ya its does run rich but im pretty sure the harmonic balancer is going cuz if im cruzing at about 70 i get this weird vibration about every 5 seconds but we willl see thanks for the idea i need to replace them any ways.
asburydan
110
Calabash, NC
Jun 16, 2010
#10
  • Jun 16, 2010
  • #10
RPM shifts
I am having a switch replaced tomorrow on my auto trans since it now "drops out of gear" and the RPM move up 300-500 as if the car is in neutral, with the gas pedal depressed. Maybe something similar is happening to you even with stick shift. Switch is M something (3 more letters, but I forgot).
9
94gt5.o
177
ferndale WA
Jun 18, 2010
#11
  • Jun 18, 2010
  • #11
i dont know i dont thinks so because my problem has to do air and fuel mixture (so i think based on how its running)
oh and i took a real close look at my HB (harmonic Balancer) and the rubber is startin to push out so i got my list of parts that need replacing lol
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Jun 18, 2010
#12
  • Jun 18, 2010
  • #12
You're talking about the MLPS. It's easy to replace on your own, but it's a bit late for that. The original MLPs the auto transmissions got weren't sealed tight ands would eventually corrode. All new ones made hare properly sealed now. Another possible problem could be: if you're in Overdrive, you accelerate and the car drops into neutral, that's your overdrive band wearing out. It's literally a kevlar band that can't really hold the torque of a V8 engine. Too many heavy accelerations in overdrive will wear out the band, and eventually you won't have overdrive anymore.
If the new MLPS doesn't fix the problem, post up in your own thread and we'll go from there.
Chythar
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Jun 18, 2010
#13
  • Jun 18, 2010
  • #13
Take care of that HB real quick, if it's out of balance it can damage the engine. Usually the engine will start shaking while it's running, and get worse the higher the RPM's go. As for losing power, I haven't seen anyone mention the MAF. The sensor wires can get dirty and rob you of power. Clean the wires very gently with a q-tip and rubbing alcohol; keep cleaning them until the q-tip stays clean.
9
94gt5.o
177
ferndale WA
Jun 18, 2010
#14
  • Jun 18, 2010
  • #14
ya I know about the MAF i acully just cleaned it 3 days ago with some MAF cleaner not sure if the q tip method is better if it is let me know oh and my o2s have about 160k on them
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
W
2003 Mustang GT issues
  • westberry23
  • Aug 25, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
