rubbing after 5 lug conv...
I decided to go the lincoln setup for since I got it free, then got a set of 17x8 tribars really cheap, so, i did it and when i turn all the way to the left I rub pretty bad on the lower arm, doesnt happen when I turn it the other way though.. :shrug: , can anybody help me please?? Thanks!
Tire size. You running 245/45/17s? It's common. The lower control arms (front) on 94+ Stangs are designed a little different to allow larger tires/wheels. Also... 91-93 has larger wheel wells to keep the larger 16 inch ponies with 225/55/16s from rubbing. Hope this helps.
Mustang5L5 said:
It's common, just gotta learn not to turn the wheel all the way.
These cars came with 15's stock...so gotta expect some problems with us all running 17's now
The rack limiters will prevent you from turning it all the way to the point of rubbing, good cheap investment!
They are not discontinued, as I just purchased some from my local Dealer a few weeks ago, and as stated above you can get them from 50resto too. I took my Service manual into the Dealer and showed them an exploded view of the steering rack and pointed to the limiters and they had them for me the next day. If I can find my receipt I will look for the Part # for you!
