Ruff Idle
  • Thread starter Thread starter Jims89cobra
  • Start date Start date Apr 3, 2016
Jims89cobra
  • Apr 3, 2016
Changed stock distributor to msd and then changed old plugs (auto lite 764's) to app764 platinum
Now my car idles up and down from 500-1500 rpm, could this be the plugs?
stykthyn
5,232
2,652
223
gainesville
Apr 3, 2016
  • Apr 3, 2016
I don't care for those plugs, but check that you didn't crack or knock a vacuum line loose.
Onefine88
Previously 89SSC18
1,422
796
154
Apr 3, 2016
  • Apr 3, 2016
Are you still running stock heads? If so go buy a set Autolite 25's and gap them at 0.54 and install them. Then remove the MSD distributor and reinstall the stock Ford distributor.
That will eliminate any possibility of an ignition problem.
Reactions: A5literMan and mikestang63
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 3, 2016
  • Apr 3, 2016
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix.
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 200,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
Reactions: Davedacarpainter
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 3, 2016
  • Apr 3, 2016
yep- autolite copper 25's and put a Ford or Cardone replacement distributor from Rock Auto back in. Never run a My Spark Died distributorr again.
CarMichael Angelo
8,909
234
Birmingham, al
Apr 4, 2016
  • Apr 4, 2016
They'd probably see that.... In the tech side of things.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
