Ruff Idle
Jims89cobra
Changed stock distributor to msd and then changed old plugs (auto lite 764's) to app764 platinum
Now my car idles up and down from 500-1500 rpm, could this be the plugs?
Are you still running stock heads? If so go buy a set Autolite 25's and gap them at 0.54 and install them. Then remove the MSD distributor and reinstall the stock Ford distributor.
That will eliminate any possibility of an ignition problem.
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :D
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 200,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
Reactions: Davedacarpainter
They'd probably see that.... In the tech side of things.
