Ruined Trans?
n2o-89fox
116
ca
I was told by the previous owner that it is a world class t-5 all my mods are in my sig plus a 150 shot of nitrous. Now my question is 1-3 gear makes a whinning noise, 3rd gear being the loudest and first and second you have to listen to try to hear it. 4-5 I can hear any whinning at all. Now the trans shifts fine, doesnt pop out of gear or grind so is this something to worry about or take it easy on until I get the fund to get a new trans? With the mods in sig it should be somewhere in the 290-300 rwhp and with the 150 shot somewhere around 420+ rwhp, and from what I read the worldclass trans are supposed to be good to 550 hp and 450tq? Guessing thats at the flywheel? Thanks for the replys in advance.
Just a little clarification...
ALL Mustang T-5's are world class. It's just the style of 3-peice synchros and different bearings.
Up til 89 they were rated at 265 ft-lbs of torque
90-later were 300 ft-lbs
Cobras got 310 ft-lbs
and the Z-spec t-5's are 330 ft-lbs.
They are all world class T-5's.
If your trans is whining...change the fluid. It may cure it, or it may do nothing. Check your shifter as well and make sure it's tight as whines sometimes come from vibrations in the base and handle.
First thing to check as everyone has mentioned is the trans. fluid. Could be a good possiblity that it's leaking and that's causing the whine. Mine whines well. WC T5's can only take so much and if you're looking to add even more HP/TQ I would look into saving up to rebuild it G-Force or buy a better trans to take the abuse it's going to encounter just my two cents. :shrug:
Here's a helpful read up as well for trans. problems. http://www.hanlonmotorsports.com/HanlonTIC.html
I checked and changed the fluid, the thing is it shifts perfectly and doesnt grind or anything. The fluid change didnt do anything really but atleast I know that the fluid is full and clean! LOL
Do you think the whine could be coming from the shifter? A lot of trans whine tends to come from harmonics in the shifter. They have gaskets you install between the shifter and trans to try to quiet it down.
