  • 1994 - 1995 Specific Tech
Running bad
  • Thread starter Thread starter 95_cobra123
  • Start date Start date Feb 25, 2006
95_cobra123
213
Lovington, IL
Feb 25, 2006
  • Feb 25, 2006
Hey guys need some help the cobra is running like crap and i cant figure out why wont pull fully like it has probelms i mean it pulls but not as hard as it should for the mods ColdAir,4.10,full exhaust headers =L bbk/Dr. Gas X-pipe/FlowM dumps, 70mm TB, 76mm MAF, And pro5.0 shifter. The timing is stock still i think never messed with it. so i think that might be it also have not put new plugs and wires in it for a yr or so not sure about that. it wont even run probly a 9.5 in the 1/8th right now i have no clue whats going on with it. ideas plz guys.
Thanks Brien
HISSIN50
34
129
Feb 26, 2006
  • Feb 26, 2006
Brien, you are not giving folks a lot to go on.
Have you pulled the codes (the CEL does not need to be on to store codes)?
Good luck.
95_cobra123
213
Lovington, IL
Feb 26, 2006
  • Feb 26, 2006
how do i do that... i really have no clue what to do that why ii am open to ideas what u mean pull the codes and CEL????
RIO5.0
6,892
N.H.
Feb 26, 2006
  • Feb 26, 2006
Hit up Fleabay and look for a OBD1 scanner...Ford specific ones are 25.00 or less....Look behind the shock tower on the pass side and youll see a plastic cover with "Test" written on it...plug it in to that harness and read away...
I would buy a scanner the spits out the actual code versus the beeping/light kind...just makes things easier...
Here you go...tad more the the numerical read-out type..
http://cgi.ebay.com/ebaymotors/OBD-...43989QQitemZ4616312989QQrdZ1QQsspagenameZWDVW
Mustangless
903
home
Feb 26, 2006
  • Feb 26, 2006
I think that is the same one you can get at walmart for 20bux. It is easier to use that then read the flashing though.
95_cobra123
213
Lovington, IL
Feb 26, 2006
  • Feb 26, 2006
could it be the mass air??? As i said i have one i just dont have it installed its never been cleaned and the car has around 93k on it. u say do those computer test and stuff... i am not sure how to use one and where can i buy one at walmart never seen one. And what is OBD1
HISSIN50
34
129
Feb 26, 2006
  • Feb 26, 2006
It sounds like you could use a repair manual from the parts store. It will be useful for providing ancillary info that people on here dont feel like typing out, as well as pics and torque specs.
Cleaning the MAF element is a good idea, but you have to be careful.
A repair manual can tell you how to retrieve trouble codes with or without a code reader. Some parts stores do it for free.
OBD-I = On Board Diagnostics, version one. It is less stringent than OBD-II. The data link connectors for OBD-I and II are not compatible so get an OBD-I code reader (your car has both OBD-I and II data terminals).
A search can reveal info really fast if you need answers ASAP. Good luck.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
F
Gauge Cluster "sweeps" ONLY when datalogging with SCT X4
  • FlyinRyan02
  • Aug 14, 2023
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 14, 2023
FlyinRyan02
F
C
Electrical New Codes 29/98/66 - wont run unless MAF unplugged (all volt and ohms checked at maf)
  • cablegod
  • Nov 5, 2022
2K
Fox 5.0 Mustang Tech Nov 6, 2022
nickyb
Engine Fuel pump not running
  • NitrusReigns
  • Dec 13, 2021
2K
Fox 5.0 Mustang Tech Dec 19, 2021
Bree
