Running Hot
  • Thread starter Thread starter 84blkstang
  • Start date Start date Oct 5, 2004
84blkstang
544
Springfield MO
Oct 5, 2004
  • Oct 5, 2004
today i got the motor working and everything was great, but it is running hot. I put in a new thermostat 180* and new gaskets and everything worked before so i dont know what is going on here. Anyone have any ideas? The waterpump is new and the radiator is also.
HISSIN50
34
129
Oct 5, 2004
  • Oct 5, 2004
burp the system really well.
84blkstang
544
Springfield MO
Oct 6, 2004
  • Oct 6, 2004
WEll i have no clue what is going on, we changed out the thermostat to the old one and it sill runs hot. It ran hot on the way home so hot that i had to pull over and wait for it to cool down. I am totally stumped for ideas. The radiator holds 3 gallons of antifreeze and water. It is out of an 84 Lincoln, The water pump is new and there is no leeks it keeps spilling over in the overflow jug I am totally stumped Can someone help me???? Hissin How do you "Burp" the system?
HISSIN50
34
129
Oct 6, 2004
  • Oct 6, 2004
a system with air pockets can overheat. to burp it:
on a cold motor, remove the rad cap. jack up the front end so that the rad cap hole is the highest point in the system (jacking or creative parking eases the air's path out). run the motor like this til up to operating temps. be sure the heater is on while doing so.
you should see some bubbles coming out periodically, as well as seeing the t-stat open at the specified temp (water will flow from the pass side to drivers side if you peer down into the rad cap hole). be careful; dont get burned or anything.
once no more air is comin out, put the cap on and take it for a spin.
if that does not cure it, please be more specific - when does it overheat? are you using a real gauge? other symptoms? etc. good luck.
84blkstang
544
Springfield MO
Oct 8, 2004
  • Oct 8, 2004
OK i havent been able to get on in a few days somthing about the server. Well here is what it is doing. Wednesday i drove it to school about 30 minutes away. (Mostly Highway) The gauge didnt start climbing until i was about 1/4 mile away from school. So i get out and it spewed coolant in the overflow tank. I though that maybe i overfilled it. Well after that i had school from 8:30-2:00 I go out there and the overflow tanks was full. So i opened the radiator and it was low. So i get the coolant out and fill the radiator. Then on the way home it got hot as hell. As i was driving down the interstate i smelled coolant So i pulled over and it had filled the overflow tank and then some. I waited about 15-20 minutes and drove it home after it cooled down. Then i havent drove it since. The water pump is new and we changed out t-stat again and still nothing. So i am gettting the radiator boiled out and cleaned and i removed the Ac radiator since i dont have it anyways. The i will try and burp the system. I am totally stumped the water pump is new also, but now a days that doesnt mean anything.
84blkstang
544
Springfield MO
Oct 8, 2004
  • Oct 8, 2004
I know the stock gauge isnt accurate but i know it is getting hot. Also it has a new sender unit, and radiator cap if that helps any
84blkstang
544
Springfield MO
Oct 8, 2004
  • Oct 8, 2004
Would not having a fan shroud cause this problem?
A
autoXr1
1,838
Michigan
Oct 8, 2004
  • Oct 8, 2004
It may be contributing, but at speed, it should be getting plenty of air.
Any evidence to suggest a lean condition?
J
JB66
565
New York
Oct 8, 2004
  • Oct 8, 2004
Maybe a supid question... Do you have a serpentine belt? If so, are you sure they gave you the reverse turning pump?
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
9
91 LX 5.0 getting hot when a/c is running
  • 91lx14gt5.0s
  • Jun 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 4, 2026
manicmechanic007
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
