N nicks199050gt Member Dec 31, 2004 67 0 6 NH Jun 17, 2005 #1 Jun 17, 2005 #1 I just hooked up my air fuel ratio gauge and my car is running lean at WOT.How do I fix it? Thanks for the help
dstanggt50 Founding Member Sep 13, 2000 1,316 0 0 Woodinville, WA Jun 17, 2005 #2 Jun 17, 2005 #2 Are you runnin an autometer guage, I've heard they aren't that accurate, unles you've got a wideband , but you can try turning up the fuel pressure.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jun 17, 2005 #3 Jun 17, 2005 #3 A list of mods would help. You also might have a faulty sensor or two, which are causing issues (assuming your WB is working properly). Good luck.
90mustangGT I felt sorry for girls because Founding Member Jan 15, 2002 2,773 17 89 Dallas, GA Jun 17, 2005 #4 Jun 17, 2005 #4 The range of a standard oxygen sensor isn't near that of a wideband but it still gives you a baseline. What is your fuel setup? All stock?
super302 I'd do anything for free Bapples May 29, 2004 2,878 1 0 Davenport, IA Jun 17, 2005 #5 Jun 17, 2005 #5 we need more info on your car
B BaXTeR3221 Member Jan 12, 2004 917 0 16 Orange County, NY Jun 18, 2005 #6 Jun 18, 2005 #6 I dont know how much faith i would put in a gauge that doesn't have a wideband o2. If your really worried, bump up the fuel pressure some.
N nicks199050gt Member Dec 31, 2004 67 0 6 NH Jun 18, 2005 #7 Jun 18, 2005 #7 Thanks for the help guys. My mods are as follows 306 block with the trick floow top end kit, dss pistons,75mm tb, 30lb injectors,255 fuel pump vortec a-trim pro-m meter aeromotive fuel pressure regulator. Thanks again for the help
N nicks199050gt Member Dec 31, 2004 67 0 6 NH Jun 18, 2005 #8 Jun 18, 2005 #8 And my o2 sensors are new but the stock ones.
