Running LEAN-What common suspects?
What codes are you getting? A paper clip is a lot cheaper than a MAF sensor.
Also keep in mind that MAF sensors are not interchangeable between different types of housings or computers. The MAF sensor that was designed for you car is P/N E9ZF-12B579-?? installed in a 55 MM housing.
The only other Ford OEM MAF/housing combination that is a direct 1 to 1 swap is a 94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter Kurtz Kustomz Motorsports, Inc. KKM Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
Try AutoZone and ask for 81413 - Spectre / 3 in. Aluminum Intake Mass Air Flow Sensor Adapter at $12.00. You may have to order it online.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
Hey Jrichker-
Im awaiting the Equis scanner from midway parts you recomended, Did i mention-I swapped in a new MAF, same crap. Surge still ALIVE and well. :( Im pretty much done with trying, figure-I'll drop the codes as you say and see whats up. Any other suggestions in the meantime?
Thanks Anthony
Hey Jrichker-
Thanks Anthony
When it comes to dumping the codes a 3 cent paper clip is a good alternative...
Just be sure that you use the STI connector and not the under hood light power when you dump the codes by any method.
03 mustang gt 2013
I have a 03 gt it's bring up lean codes on both bank 1 & 2 said bad oxygen sensor bank 1 I replaced it and the car is still idling rough .. idles f 1000rpm and under some time stalls out when running car as bbk intake bbk 70mm throttle body 2 step launch control headers cammed ...help
03 mustang gt 2013
Welcome to the boards!
Best bet is to start a new thread in the appropriate sub-forum. Be sure to include info about the length of headers (it it's LT's, that's a biggie), how the car is tuned, and recent work done to the car before it started acting up.
Thanks for the info. . I just bought the car im go off what I see .. the headers are LT and I don't know about recent work done or if it's been tuned
I think he has a thread already
Reactions: Keepitford
