Running Nitrous Line...
Well I have all my solenoids mounted on my car, and now I'm going to run the nitrous line from engine bay to the trunk. Are there any holes in the trunk I can run the nitrous line through?? Or will I have to drill a small hole?? And what do you guys attach the nitrous line to the bottom of the car?? The fuel lines?? And do you guys just use zip ties??
I just ran the nitrous feed line through the rear quarter panel and underneath the side step (left of the driver's seat). Then I ran the line through a grommet right next to the master cylinder.
Did you have to drill a hole through your trunk to get the line to the bottle?? Do you have any pics??
No I didn't drill a hole. The line goes from the bottle nipple to the driver's side rear quarter panel near the back seat. Then I routed the line underneath the foot panel (not sure if that's the exact name, but its the plastic strip near the side skirts of the car).
I ran my feedline through the interior of the car under the carpet and panels.
Although if you want to run it under the car you can there is a grommet that pops out in the trunk it is almost directly over the rear axle. It is where my Blowdown tube exits the car. pull your carpet up and you should be able to see it.
+1
Thats what i did. under the rear seat on the pass. side then hid it under the panneling and kicker pannel. then under the a/c to a rubber gromet thats already there in the firewall. then i set up a solinoids on the passanger side. Then for giggles i spray painted them black so it looks like a/c stuff and plummed th nozzle on the under side of the intake tube. beddy beddy sneaky(mr deeds)
