Running on 2 cylinders ??
dave's red89lx
Fresh rebuild, TFS street kit, 24 # injectors Installed the cam @ 12 and 6, new autolite plugs (3924), new cap,rotor,wires and coil. tried to fire it up, sounds like a tractor and will not stay running. I then checked and have spark at all cylinders. Pulled the plugs, and they are soaked with fuel. I then started feeling around the headers, & number 3 and 5 are hot but the others are cold. Does anyone have any Ideas on what to check next? I am at my wits end.
Any help would be great.
Dave...
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
the timing marks for the crank and cam gears meet each other at 12 and 6 o'clock respectively (also called "dot-to-dot") and the piston in the No. 1 cylinder at top dead center on the compression stroke (both valves closed) are you sure this step was performed correctly...
you can also have only 2 cylinders fireing if wires are put on backwards being clockwise firing order yours should be counter clock wise as in pic. below but with the wireing backwards 1 and 6 would fire......
Found the problem
Thanks for all of the info guys, The problem was that I had adjusted the rockers incorrectly. Now I just need to read through the Surging idle checklist.
Thanks again.
Dave...
