Running Rich, HELPPPP!!!
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Im having problems with my car running rich, when i bought it the guy said it was basically ready for boost, but i cant afford any of that right now so my question is, can i simply dial back the fuel pressure going to the injectors they arent that great deal in size only 24lb, i heard that stockers are only 19lb but the car has a 255lph walbro fuel pump, at least i think its walbro but anyways is it simply me just adjusting the fuel pressure back or is it much more then that, sorry i am a noob with this kind of stuff
There is so little technical detail in your post that it is very difficult to give you any advice. It sounds like you have very little mechanical backgound and bought someone's unfinished project car because he talked a good sales pitch.
What year make and model is the car? You didn't say: you could be driving a Chevvy for all we know.
What cubic inch size engine?
What kind of computer - Speed Density or Mass Air? Does the computer have any kind of aftermarket or custom chip?
What cylinder heads, intake manifold, cam, cold air kit?
What MAF if Mass Air? Is the MAF calibrated for use with the injectors?
Ok sorry I did not know I needed all that in such a simple post ... its a 302 with a .030 overbore forged 10:1 pistons with eagle h beam rods stock turned crankshaft custom ground lunati cam shaft 75 mm maf sensor going to a 70 mm throttle body
Holly systemax upper and lower intake manifold full custom exhaust ... what happens is it runs rich at idle but seems to lean out when I drive it and get on it pretty good and sorry if I sound like a noon with this **** but this is my first project car in which I did not start from the beginning
Oh probably don't matter but it has fluidyne aluminum radiator with dual electric fans
Rebuilt t5 trans
Aluminum driveshaft
4.10 gears
Mosley 31 spline shafts
Oh and its a 1991 ford hatch 5.0
1.) MAF calibration must match injector size. Check to see that MAF sensor and MAF body are compatible. Check sticker or manufacturer's part number on MAF against their website to make sure it does. If it is a C&L MAF, check sample tube size and color.
2.) Check fuel pressure at idle
Check fuel pressure:
The local auto parts store may rent or loan a fuel pressure test gauge if you don't have one.
Disconnect vacuum line and check it for evidence of fuel present on the line. If you find fuel, the fuel pressure regulator has failed. Cap the vacuum line and stow it out of the way.
Connect fuel pressure test gauge to Schrader port located just behind the alternator.
Turn the ignition switch on & start the engine. Observe the pressure : you should see 37-41 PSI at idle.
Turn the ignition off, reconnect the vacuum line and disconnect the fuel pressure test gauge. Watch out for squirting gas when you do this.
3.) Dump the codes to find sensors that may be out of spec and causing problems. Codes may be present even if the check Engine Light isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Ok well is the schrader port in the same spot when it comes to all lower intake manifolds? I have a holly systemax if that helps .. sorry if im sounding like a complete idiot but I didn't think that me buying someones started project would be this complicated ... oh and checked the maf and it says on the top of it calibrated to 24c but Idk what c means if you don't mind telling me I appreciate it
There is only one schrader valve on the fuel system. It is the high pressure supply line that feeds the injectors. That is where you connect the fuel pressure test gauge.
Oh ok I already have a gauge there .. I must've mis read it thinking it was behind the altenator but this one is on the fuel rail feeding the injectors ... took the vaccum line off and it jumped up to 40 psi ... put vac line back on and it dropped back to around 30-32psi
Thats exactly what it should do.
Hmm ok ... talked to a buddy he's saying since its cammed I will smell a little bit of un burnt gas but im gonna clean my maf and then check out my o2 sensors and see if that might change something
