running rich
865.0trunk
Canada
ok i have an 86 5.0 trunk. i converted this car from a 4 cylinder and put a full 88 dirvetrain in it. i put on long tube headers and a full flowmaster exhaust. the car is running and starting up fine, the problem is when i give it gas. if i put it to the floor it is very sluggish it takes about 1 second before it starts to rev up, and when it does it revs up slow. the motor has been sittin for a while but i have been running it.. when i rev it up it is very blue and smells really bad of unburned gas. i took it outside and put the pedal to the floor, on ice the car wouldnt even spin. i havent done a tune up on it yet, (plugs wires etc). have all the polution equipment removed. can someoen please help me.
also the long tube headers i put on, they come apart off the collector, and they are leaking a bit, the guy told me they will seal when they are bolted down, they dont seem to be sealing, could that be a problem, and the 02 sensor only goes into 1 primary tube. thanks guys i appreciate your help.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
