873Stang New Member Jun 19, 2006 221 0 0 riverside Jan 27, 2007 #1 Jan 27, 2007 #1 running slightly rich, wondering what could cause this??? and sometime if i rev or go wot i can smell raw fuel (nox) i dont know where to start??
craigwhite89gt New Member Oct 26, 2003 181 0 0 Cecil County Maryland Jan 27, 2007 #2 Jan 27, 2007 #2 whats done to the fuel system? injectors? Mass Air?
stangster50 New Member Nov 19, 2006 129 0 0 cranston ri Jan 27, 2007 #3 Jan 27, 2007 #3 do you have cats? that will cause it to smell rich also. not having cats i mean...
873Stang New Member Jun 19, 2006 221 0 0 riverside Jan 27, 2007 #4 Jan 27, 2007 #4 nothing dont to it all stock besides an elec fan still has factory cats. i changed my gap from 45 to 56 and that helped alittle. and i have an autometer air fuel gauge so at idle its in the lean driving it goes between rich and stoch i think is the word.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jan 27, 2007 #5 Jan 27, 2007 #5 The narrowband gauge can be misleading. I wouldn't make determinations based upon it. Also, isn't excess fuel HC's? Check for a vac leak at the MAP sensor (if applicable). If a proper vac signal is not reaching the MAP, it can cause rich running. Good luck.
vristang 15 Year Member Mar 31, 2005 4,933 101 124 Seattle Jan 27, 2007 #6 Jan 27, 2007 #6 Start by pulling the codes There is a link in my sig if you don't have a scanner... You may get lucky and have the computer tell you exactly what is wrong jason
