running rich???
five0mustang89
iv got a 89 5.0, i just put on a holley systemax intake, # 24 injectors, 70mm throttle body, 90mm MAF, and a cold air intake, and it had a e-303 cam in it when i bought it. it still has all the EGR stuff, and it runs fine at driving RPMS. when i come to a stop the rpms dip below idle and the car will almost stall, but then it jumps back up to idle. also, sometimes when i get off the highway and put the clutch in on off-ramps the car will die. and lastly when i try to do a burnout the car will stall. so i know the car is running rich, i can smell it in the exhaust, but will that cause these types of problems, and if i buy a chip will that help at all...thanks
Your problem is covered in the sticky...
You guys with idle problems could same a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first post has all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix.
He's right -- here's a quote from that thread that let me to EXACTLY what my pig rich at idle problem was:
If that doesn't do it check the 12vdc to the heater on the O2's. One smack of wiring on headers wipes out the fusible link hidden in the wiring on the engine side of the firewall where the main puter harness goes through. This will cause the o2's to slowly go out of tolerance and the puter flips out. check this if the car's running really rich a idle too. Ranchero got nailed when first installed and the '93's done it too. I actually ended up soldering on a stereo inline fusible link and installing a 20a fuse to make the repair quicker.
More to come as I get time...
Jamie
If you follow that checklist, I have no doubt that you can solve your problem.
