Holy mother of hack jobs. I'd see if you can get an entire harness from teh same year from MPS or otherJY and start fresh.
You really think that might be needed at this point?
can you define what a "bigger intake and injectors" is.? Is the MAF an aftermarket matched to the injectors or a stock Ford unit. Gas in the oil is either because your injectors are too large, an injector is stuck open, a bad FP regulator or incorrect FP setting, or improper tune. Was the car sitting for a long time or was it cranking a lot with a no start situation? You want tp avoid washing out your motor with fuel or you will end up ruining an engine quick.
I'd be suspicious of that computer have'n the back open like that. Its a remanufactured I think. Also throttle body and maf looks stock tto me but really can't tell from pics, likely from the explorer that the intake is from, not a bad thing. Need fan shroud and puke tank. At this point I don't think a tune will do any good till you identify some of the claimed mods, but I am not a expert, pervious owner's don't always tell the whole truth and nothin but the truth, does it have a lopy idle?
Can you imagine what the greedy stealers or equivalent would charge to deduce a Frankenstine combo and get right. This is why you try to get part numbers and lists of parts that previous owner installed. It would be absolutely ducky if previous owner knew what he or she was doing, and sold a car running like it should. With all the hi po parts working in harmony. I haven't read one yet. When I used to build fast bikes in my day, I jetted them/ tuned em, then released them. Maybe it's just me!
Sent from my iPhone using Tapatalk
Did you push the clutch in when you where running codes?5 speed.
50lbs of fuel pressure will make a 19lb injector act like a 24lb injector...
First readjust the fuel pressure to 40-43lbs with the vac line disconnected from the regulator.
No code 11 means there is an eec error. Check the harness for the o2 sensors near the header if it was burned against it a short to 12v will kill the eec.
A t5 ecu with an o2 harness from an automatic can/will cause this same issue. When cranking 12v gets applied to vref pin in the ecu burning the trace.
How to tell if you have the right harness.... there are two wires (black with yellow stripe and blue with yellow stripe?) If it loops back into itself at the o2 harness plug, it's for a t5. If they don't it's for an aod.
Check these things and let us know.
If the ecu has been burned it is fixable, a jumper can be soldered into place around the burned out trace.
Ahh..I've seen this before and know what the lack of a loop in O2 harness means.
You have apparently an early 1988 model car? Can you check the date code on your door jamb?
So, this is a very little understood issue. 1987 cars and early 1988's are lacking 3 wires in the main engine harness, and the loop in the O2 harness that jumps them out. The lack of wires isn't a hack, it's how it came from the factory. These wires are usually what sends a code 67 to the computer if not present after a mass air conversion
in mid 1988 when ford added mass air, they started adding these wires to all mustang engine harness, and from 1989 on it was present. Some speed density 1988's (like mine) also got them prewired.
I made a thread on this a while back
http://www.stangnet.com/mustang-for...-harness-differences-etc.892849/#post-8994084
With an A9L and lacking those 3 wires, you will forever have a perpetual code 67 and unable to pull engine running codes. Many guys with MAF swapped 1987's also report the car running like crap, until they swapped the engine and o2 harness out with a late 88-89 harness and o2 sensor harness.
This one we can't blame the original owner on because it' not common knowledge that there is a difference in the wiring.
Also, I notice you have a VSS code, and a code 95. That would suggest to me the original owner took a shortcut and did not tap into the VSS wiring, or the fuel pump wiring when he did the MAF conversion. Now, the fuel pump wiring is not critical and it just informs you your pump is dead, but the VSS ones are pretty important. First, verify your 1988 does in fact have a VSS underneath and is plugged in (87-88 without cruise control do not have a VSS) and then secondly, you'll need to tap into the two wires for the VSS and pin it into the EEC.
Dang!!! Never mind...I started reading the post...sounding like a engine harness issue as well...not what I was looking for...
