running water instead of antifreeze
jcwhite1288
38
Ive been running water in my radiator since ive been driving my car and ive heard that if i drain my radiator and use antifreeze it'll mess up my whole system. is this true cuz the water is not doin it for my engine lol
you want to run a mix of water and antifreez. you also want to be using distilled water, not just the garden hose variety. it will NOT mess up your engine. if you run straight water, you will have a lower boiling point, and a higher freezing temperature, which will be bad.
Running straight water will reduce your running temp (which is why NASCAR's run straight water, it disburses heat faster than with antifreeze), but you obviously run the risk of freezing if it gets that cold where your at, which is real bad.
In any case adding antifreeze will not hurt your car. The distilled water thing is good as well as it puts less "crap" in your cooling system that could aid in rusting your internals.
Runnig water alone will rust internals in your engine. You could be setting yourself up for freeze plug or water pump problems. Make sure you have some sort of anti-corrosive mixed with the water or you will be in trouble down the road
drbobj67 said:
From what I've heard straight water is not a good idea, something with rust/corrosion protection is a good idea. As far as research goes here are a few items to check out.
http://www.streetrodstuff.com/Articles/Cooling/Cooling_Suggestions/
http://www.jag-lovers.org/xj-s/book/CoolantFilters.html
http://www.classicchevy.com/product.asp?pf_id=49-71&dept_id=1249
http://www.stockcarproducts.com/cooling1.htm[/QUOTE"]
"Only use the amount of antifreeze that your demographic region dictates. Basic chemistry tells us that pure water is the best coolant, period"
thats why i add a corrosion inhibitor like 40 Below
They use water and water wetter incase of track spills. You cant run antifreeze on a track, or not supposed to.
FYI
The heat of fusion for ethylene glycol is 43.26 calories per gram, or
about half of that of water. So if you freeze a mixture of water and
ethylene glycol, you will actually be storing less cooling energy than with
pure water. The mixture may be colder, but it will adsorb less energy.
