Runon with rich mixture??
  • Thread starter Thread starter SmockDoiley
  • Start date Start date Feb 22, 2006
SmockDoiley
1,591
San Diego, CA
Feb 22, 2006
  • Feb 22, 2006
I know running lean can cause a dieseling effect when shutting off the car, or having too much timing, but Im pretty sure I have neither. My 460 is very fresh and Ill include the essentials to help with your diagnosis. I've checked for vacuum leaks and come up short, all bolts are tight and all lines are hooked up. Im pretty sure she's running rich due to the stinky fouled sooty plugs, gas smelling oil, and having to open the choke to get it to start(gets more air to help combustion, lean out mixture), and you have to blip the gas to "clear her out", and it smells like a lawn mower. The timing was set at 8* and it has dieseled on me and now its set at 11, which is still really low. The exhaust manifolds arent leaking to allow for air to get in. Can being too rich cause run-on? I was pretty sure it wouldnt but I could be wrong.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 22, 2006
  • Feb 22, 2006
Excess fuel will cause dieseling when you shut off a carbed engine.
Many years ago I drove an MGB that had extra rich needles in the SU carbs. The engine would diesel badly when you shut it off. Since SU's don't have an accelerator pump, the fix was to turn the key off and floor the throttle. The extra air stopped the engine from dieseling.
SmockDoiley
1,591
San Diego, CA
Feb 23, 2006
  • Feb 23, 2006
I'm starting to also think that the comp is higher than I thought and the last time I got gas I bought 87. It really knocks good too if you try to start it when its hot.
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
