hi, I have a 66 with the I6 and 3spd manual. the car was sitting for probably about 4 years before I bought it and this past weekend I got it running again. I was going to pull it out of the garage, just to straighten up a bit and sweep under it, and when I put the car in gear and let out the clutch it shakes a bit (not badly) then stalls out, but doesnt move at all. I checked the rearend by jacking it up and the rear wheels spin freely, and if i turn the driveshaft by hand the wheels turn with no problem in both directions.
One other thing is that the shifter handle is loose on the mount (about 1/8" of play in it) I cannot tighten the bolts any further, so i am thinking it may be the wrong handle. Also when shifting to reverse or 2nd the shifter handle makes contact with the opening in the body, i dont think it has enough room to fully get into reverse. any ideas what could be wrong?
